shaking on braking
#46
Chances are they been slightly cracked for years like everyone elses at this years and mileage- only if they were really bad I could see doing it.
Did they check the inner and outer tie rods for slop?
#47
#49
Don't forget about the indy shops, really no need to hit up a dealer to do it.......Have a look at http://rockauto.com or a local auto parts store for parts prices to give you a idea.......
#51
The Thread Starter is convinced his shaking on braking is NOT due to his brakes because his shop tells him so. I'm not convinced, but my posts have had little influence. I suggested he resurface his existing rotors or replace them with quality aftermarket rotors. He has no money for this, but is apparently considering much more expensive repairs.
#52
#53
This was an interesting thread about engine noises the OP of this thread was hearing. Most of the regulars told him it was a pretty normal sound, his shop down the street indicated it would be an expensive repair. In the end, it ended up being normal. https://www.clublexus.com/forums/rx-...ing-bad-3.html
I see the similarity in this thread and the one you referenced!
#54
are u trying to rip on me here or something just because i know what im saying to be true yet u dont seem to think i know much? what i can tell u is i trust the people at the shop i mostly have gone to for a majority of work i needed done are trustworthy and then some and that is that end of discussion..
#55
#56
BTW...have you considered trying 10w-30 oil for your start-up noise? It worked for another poster.
#57
matts6887, Your shop should have a service writer or tech, to ride w/ you & also drive it, so they know what your talking about so they can figure out what the problem your having w/ your shaking issue. Oh & 'bout your youtube vid.....There's nothing wrong w/ the noise your engine is making for that is normal for a Toyota 2gr engine. Yea it does have a more mechanical noise then other engines, but it also has stouter parts then other engines as well.....such as roller rockers, forged crank, rods & it is a open deck block as well.....IDK what kind of vehicles you've had before, but this engine design works for Lotus as they're used in the Evora S & Exige S cars w/ a blower....Possibly have a listen to Rat or Mouse motor w/ a solid lifter, gear driven cam w/ your choice of cam duration w/ headers to give you a idea 'bout mechanical engine noise.....
#58
#59
