Fluid leak!!
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20201020_100755_ab0ef69ae200e65eea119fa82b323716135a8d5b.jpg)
Does anyone know what this cap/ port is called? Its leaking what appears to be ATF fluid or coolant?. It's below the exhaust manifold next to the oil filter. Thanks!
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20201020_113233_05566d0a05e0e41f998e2572183b50b74fe9d555.jpg)
My guess was coolant because of the location? But it also seems thicker/oily, like ATF to the touch? Strange...
red in color is usually either trans fluid or coolant. In either case u definitely want to attend to it right away especially if its coolant as losing too much of that equals overheating.
yea it is coolant now that i looked at the pics better. Better get it fixed and asap!.
as long as its cool to the touch like in the morning; I would take the radiator cap off and fill it with coolant. Same with the overflow tank; but u again u definitely want to get that leak fixed asap.
just make sure the rtv u use is made specifically for high temps; otherwise it may not last that long.
At your mileage, may as well do a complete coolant drain and fill, make your coolant mess at the radiator drain plug and block drain plugs. BTW, Toyota SM specs a different FIPG (Form In Place Gasket, aka RTV) for coolant contact as compared to oil contact, but seems people use the oil one everywhere without problems.
