tips/suggestions on a 2009 RX350
All,
I am the happy owner of a second RX. I just bought another one this weekend. I purchased a 2009 RX 350 in spectacular condition. And ridiculously low miles of 118k.
I love this car and was motivated to get a 2nd one because my original made me so happy. (2004 rx330 with 280k)
now my wife has one and I have one. I wanted to reach out and find out if anybody has any specific tips or suggestions in regards to this specific lexus model.
Usually when I get a car I do a few specific things as a new owner. 1) Drain the oil and put in fully synthetic oil, 2) change air filter, cabin filter, 3) sometimes I change the plugs to iridium plugs.
Any tips? I want to keep this thing pristine and see if this one can also go over 280k.
Bruce
Bruce
Margate330 (12-22-20)
I'd make sure that the oil cooler hoses are changed to metal lines vs the rubber ones, as well as swap the vvt hose to a metal line on bank one (rear head) as that one is spiced w/ a rubber hose vs bank two (front head) which is all metal line.....I'd also grab a gallon of Valvoline Maxlife trans fluid & a Wix trans filter, remove the pan as that gives you a change to clean the two magnets.....also get a couple qtrs of Royal Purple 75-90 gear oil, drain the rear diff as well as the transfer case...I also went w/ a K&N drop in air filter as well as a Wix carbon cabin filter...If it needs brakes, A great cost effective upgrade is swap out the front brakes for the gen 3 setup.... The pads/rotors are basically a wash, the additional cost of the calipers are worth it.....One look at the size difference of the pads & rotors as well as the single piston vs two piston calipers says it all....I also went w/ SS brake hoses from Tirerack as well which fit either caliper.....as well as flush out the old brake fluid.....The pedal is a lot more firmer as well as the stopping power....
The oil cooler lines are fairly easy, the bank one vvt line is a tad bit tougher....I'd say two hrs max......I used a Dorman cooler line kit & went to Lexus for the vvt line......
All,
Bruce
Bruce
All,
Bruce
Bruce
What color options?
Did you get a good deal?
All,
Bruce
Bruce
I usually do the same. I change oil every 5k and transmission every 24k. My car currrently has 166k miles and running like a champ. My brother has one with 289k and everything is original. These things are built to last.
matts6887 (12-23-20)
Also check if your car is included in Limited Service Campaign (LSC 9LH) https://static.nhtsa.gov/odi/tsbs/20...09599-9999.pdf - but, the indicated hose still from rubber. So, I used the VVTi hose "all metal", PN is 15772-31030.
Congrats about your new car.
Joey97
04-11-12 04:38 PM
