P0351 Ignition Coil Pack Cylinder #1 Nightmare(solved)
Hi members,
I had my car packed up to the ceiling with Christmas presents and luggage to go on vacation and as I started the car up to pull out of the driveway I threw a P0351 check engine code.
What are the odds?
I'm so grateful this happened now and not on the road but this error code kicked my a** for 5-6 hours and I do DC diagnostics for my job.
Had to go in much deeper than I wanted to see what the heck is going on.
Long story short the car was barely idling and then ran good and then bad- something was dying but all I had was that one code.
So I pulled the intake manifold and swapped out coil pack #1. Fun!!! lol
Put it all back together and the P0351 code came back on instantly upon starting the engine and car still ran badly and in limp mode so after a lot of diagnostics I thought I had a bad ECM the way it was acting intermittently.
In the end- problem was traced to a faulty/dying coil pack #2(front bank!) shorting the IGF feedback for ALL coils- so my scanner basically lied by not telling me the whole story.
End of story- sometimes if a coil pack fails in a special way a P0351 is really a P0351, P0352, P0353, P0343, P0355, P0356 but the ECM leaves the extra codes off. This could lead to a replacing a coil pack on the wrong cylinder and possibly an ECM by mistake when it was neither.
>> If I knew then what I know now it would've been a 10 minute repair so I am sharing my work below for anyone who needs it...
What are the odds?
Mesquite77 (12-26-20)
ugh! that doesnt sound like fun at all!!! sounds a bit too complicated for me to endure! but yea better at home then possibly stuck on the road somewhere in the middle of b.f.e (most of u should know what that means)
Margate330 (12-26-20)
Nice post. Getting at those bank 1 plugs/coils is a character builder! Did you also remove the cowling, or just the manifold?
I had a zero compression case (broken exhaust valve spring), and did a similar thing chasing misfire codes all over the place, compression test told the story...
Hi members,
What are the odds?
What are the odds?
On the RX330 since I don't install the rear manifold support bracket bolt I don't have to remove the cowling(just a push in & pull up motion for me) but since I removed the manifold once to swap the coil pack and a 2nd time to inspect wiring since still throwing code for cylinder #1 yeah that sucked when it was coil #2 on front bank that was causing all the problems...
Once I realized this it was fixed in 10 minutes by pulling the coil pack plugs one at a time until I had my 5V back and pulsing on pin 2.
PS- bad coil cylinder #2 had a crack in it when I located the problem- should've pulled all coils for inspection first. yeah I feel dumb now but I trusted my scanner too much and cost me a lot of aggrevation. lol
matts6887 (12-27-20)
Only the #2 coil pack was shorting intermittently but it was shorting in a way that it was grounding all the feedback pulses for all the other coil packs and because of this the ECM should've reported all the other coils bad too- since there was no feedback pulses for any of them.
matts6887 (12-29-20)
true that!! nothing worse when it comes to vehicle repairs to throw parts/money at it only to find out ya got the wrong part etc
Just got back from a 1,500 miles trip and car hasn't run this good in months.
All the slightest engine vibration is gone and can barely feel car running so I think this coil has been throwing weak spark too for a while before it finally died.
Forgot to take pic of cracked cylinder #2 coil pack before I left so here is something to look for on all front plugs before removing manifold on a P0351 code and maybe get lucky- and if they do have to pull manifold may want to inspect all coils while in there so you don't go thru what I had to.
Dead/Dying coil...
Dead/Dying coil...
Dead/Dying coil...
Dead/Dying coil...
So I'm having a similar issue on a GX460 and used this post to do some debug.
It seems like if there is a bad plug that IGF/pin2 would be pulled down on ALL harnesses? And if you disconnect the bad coil then IGF/pin2 should show 5V on any harness?
What I am seeing with my issue:
on #1 wiring harness (disconnected from coil) I have 12V power, but never see 5V power on IGF.
I've tried this with all other coil harnesses connected, and I tried with #3 disconnected.
on #3 wiring harness (disconnected from coil) I have 12V power, the 5V on IGF, and the pulse on IGT.
I'm having trouble reconciling how one of the other coils would be bad if the #3 harness IGG/pin2 has 5V while #1 harness does not.
This seems like a short with the #1 wiring or ECM, right?
