Tool Reviews for Affordable DIY
Relay Kit and Stubby Gauges
From Left to Right: the telescoping Lisle Hood Prop. You can prop up hoods, liftgates, and I've even used it on the brake pedal to help me bleed brake lines. Current price is about $30.
Next is the Bead Buster. I just used it the other day to change a TPMS, and I didn't scratch the wheel. $120.
An old school "Short Finder" I picked up off ebay for a few bucks. The idea is to keep the circuit live long enough without blowing the fuse and moving the gauge over wire harnesses. The needle will move and lead to the break in the wire.
Then there is relay bypass switch kit with amp loops. This cost about $80 and could save a trip to the mechanic with the fancy computer and fancy tools.
Finally, a pair of Yellow Jacket AC gauges for quick and easy pressure checks without the hassle of hoses and loss of refrigerant. $60.
Those stubby Gauges are sweeeeeet.
I just picked up a used Ultrasonic Detector off ebay for $125. This neat bit of kit can be used as a "stethoscope" and detect the >20khz frequency noise made by air leaks.
With the Transmitter, it can detect windshield and door gasket leaks. A youtuber made a video explaining how these devices can be useful:
Below is a smoke machine I got off ebay. Some guys make these at home and sell them on ebay for about $90, which is hundreds less than a fancy smoke machine that does the same thing. Next to it is hose removal pliers, Lisle 47900, that only cost about $10.
Margate330 (06-18-22)
I'd add a long 17mm rachetting wrench for swapping out the rear rotors, as its tight w/ those bolts, I need to find mine soon.......
How many psi do you need to run it?
Got rid of my big air compressor but I have a small pancake, you think that will be enough air?
I've never used a smoke machine so I don't know how to make the smoke.
The can has a small amount of Mineral Oil in it that is soaking a wick-covered wire. Wire heats up the oil and produces smoke, smoke is pushed out by air. Simple!
Not a bad deal. A decent ratchet is more than this buy itself. They also have other deals
https://www.acehardware.com/departme...keyword=664353
The regulator you see sticking out the side is set really low, like 1 psi, I think. A small compressor is plenty.
I didn't know Ace Hardware sold Craftsman, too. I thought it was exclusively sold at Lowes.
I've always bought snap-on tools because of the quality and the dealer comes to you. I use other brands as well.
Margate330 (06-21-22)
Snap on tools are cool
I'm a Snap On fan but a little expensive for me even tho they are awesome.
You have anything in the Box you like to share that you consider a must for DIY for our cars and worth the money?
Plz post pic and description if you do and if ya want to.
I think a coolant pressure tester is a must have for finding visible leaks(ones that will be visible when you use the tool but hard to see otherwise) and checking repairs.
Also one of these makes refilling your cooling system a breeze, but you need an air compressor. Auto supply places probably have reasonably priced units.
Margate330 (08-07-22)
This little bugger saved my sanity! While replacing the radiator on my 2005 RX330 this past fall, the bottom screws holding it into the bracket were some corroded, stuck demons. This extractor got them right out!
Just a tip: be sure to drill the initial guide hole deep enough for it to catch.
Also, my cats bought me a 293 piece Craftsman mechanic's set for Christmas. My late husband was a "junkyard dog" and swore by them.
I think it cost about $8, but it's probably cheaper when you don't live on top of a mountain!
I’ve been putting together a tool collection to start doing more than brake changes and oil.
two weeks ago I ran to the Home Depot one morning when I found out the night before that they had a ridiculous sale on their 1/2” ryobi P262 brushless high performance impact driver which torque test channel pushed out 600 foot pounds of nut busting torque and around 500 fastening torque. Anyway the amazing deal was get the tool free when you buy a battery pack with a charger and a bag containing a 2.0 amp hour, 4.0 ah and 6.0 ah battery. It was a g d steal *****.
was looking all over for a good deal on an impact gun and almost got an older used ingersol rand for 250 but the TTC really showed me the beans this thing put out.
Then today I grabbed a set of Mac tools 12 piece metric flex head ratcheting combination wrenches for $160 they are used but all still nice and function. A couple wear spots on the finish but worth it for the price.
also grabbed a 2.5 ton floor jack for 30 and 2 pairs of jack stands for 15.
then I went on a harbor freight spree got the 1/2” and 1/4” torque wrenches for$11.99 each then a set of deep and shallow impact sockets, 2 magnetic tool trays, an extending magnetic pickup tool, a wire brush drill bit thingy all for $93
now I have to get me some of those loop end hose pliers, clip removal pliers, a harmonic balancer puller, 24” chain wrench, a cam/ crank seal installer tool, and a 22mm high mass impact socket and I can stop making my fiancé worry about all the tool buying.
Then I have to start buying parts to use with the tools lol.
I was going to get a cheap ****ty / just good enough impact set from Amazon but after I saw this deal for just 199 I had to spend the little extra for this high quality impact gun.
It took me a few weeks to find a set of metric flex head ratcheting combination wrenches. Had a set of blue point ones lined up for $180 but they decided to keep them luckily this was just a few extra miles and a 6 point ratchet mechanism instead of a 12 point.( the guy had them advertised as an 8 point lol)
I see you are new so Welcome to Club Lexus, glad you are here!
All rusted out and this may have saved the day instead of me mangling by brackets to get it apart. lol
I've never used one of those pneumatic coolant fillers but I just broke down and got the big funnel kit the attached to the radiator cap hole.
Haven't used it yet but our cars are so overheat when not getting all the air out, happened to me too and I'm no amateur at this.
