4 L per 100km when idle?
Old 02-12-21, 12:51 AM
Nooblex
Nooblex's Avatar
Default 4 L per 100km when idle?
i am coasting or going down hill, consumption shows 3 to 4 litres per 100 km.
is this normal?
Old 02-12-21, 07:55 PM
iMSQ
iMSQ's Avatar
is this normal?
Do you want more or less? )))
PS: "Real" consumption can be computed with the next algorithm.
1. Fill the full tank (until gas pump is turned off automatically), reset Trip A (or Trip B) ODO.
2. Return to the same gas station and the same gas pump when the tank is almost empty.
3. Fill the full tank (until gas pump is turned off automatically). Divide milage from Trip A (or Trip B) ODO by number off gallons shown on gas pump. Now you have your average MPG.
4. Repeat points 1-3 several times.
Old 02-12-21, 09:33 PM
spinellib
spinellib's Avatar
If you "coast" downhill at 10mph (or kilometers or whatever you people use) the computer will show a lower MPG than if you "coast" at 50mph because you are covering less ground at 10mph.
Coasting consumption is not a good way to calculate fuel usage.
Take the advice of the post above by iMSQ.
mtd2198
RC - 1st Gen (2015-present)
02-12-21 03:52 PM
ct200
IS F (2008-2014)
08-30-18 10:51 AM
waynedog
02-04-13 07:12 PM
sydtoosic
05-30-12 11:35 AM
stvincent
03-29-10 11:20 PM
Quick Reply: 4 L per 100km when idle?
