CEL when I go fast round a bend
My XP 30 day trial license expired so Techstream down at the moment. I’ll sort it soon.
But here’s the thing I’ll be working out. Just posting this for some ideas.
When I drive (2005 RX400H) spiritedly round a bend my CEL pops up. I can clear it. If I drive like a saint it’s not a problem. Taking corners like grandma no problem.
I’m foxed. I’ll report with the code soon. Any ideas in the meantime? Could it be fuel or oil sloshing? Oil level is correct. I keep my tank filled with gas.
I do cane the car. I love the acceleration and have always been impressed by its handling for such a heavy, tall vehicle.
But the hard cornering and CEL trigger is a mystery to me.
Very well could be one of a few evap codes, I'm having that issue, when whipping it around a few S curves, specially on one two lane S curve onramp to the 405. I was thinking of replacing the evap canister, no sure yet as I bought one a couple weeks ago & a few days later the mil/vsc lights went out then last Tuesday the mil came back on, so I turned it off this afternoon.
It did once after driving a hundred miles or so, then the mil & vsc came on at which I deleted the codes. I'll see if it comes on later on.
Vincenze (03-14-21)
Just for giggles, does it only happen when you take a Right turn or a Left turn, or both?
My first instinct when I read your post was "short to ground," as in a wire loom (harness) is moving around and making bare contact on metal.
Maybe it is a connection. I did put in a new Denso O2 sensor on B2. That caused the last CEL. I checked the sensor resistance. It was between .8 and 1.2 ohms.
Anyhow I need to do a Techstream check. Blooming XP licence in my Virtual Box VM popped its 30 day clogs.
Seems like it doesn't matter....Now I just just let it roll thru the first curve which I pick the inside in 3rd gear, which gets me the outside lane on the next corner to accelerate onto the 405.I have a choice of onramps as 515 is between to different onramps.
I'd still check for stored codes just so I'd know what was troubling the PCM.
Vincenze (03-16-21)
The evac codes that showed up on my wife's rx was thanx to me topping off the fuel, as thats what I do on my powerstroke's.....Diesel fuel is like beer suds, it'll take about additional 3-4 gallons after the nozzle shuts off. Haven't done that since, so looks like its possible that the evac canister is ok.......That saved me a few hundred for the part, but do miss the additional range.
Vincenze (03-19-21)
It's a pain for me to drag out the old laptop with Techstream- plus- I never know when the car is gonna throw a code,
I use my OBDII scanner the most and it lives in the car with me at all times. lol
Waiting to see those codes and what you figured out, very interesting.
Now I will be able to revive my VM that sits on my Mac and runs XP (cos that’s the easiest operating system for Techstream install).
Next I’ll hook up for codes. Funnily enough the CEL warning has disappeared. I’ll be looking for storeds.
Vencenze, after rereading your original thread & since your mil is off, I'd say its possibly your evap canister getting sloshed w/ fuel. No issues w/ oil being sloshed around in your engine. Really more like fuel be sloshed around. I learned not to top of the fuel after the nozzle cuts off. I can learn not to add a additional gallon or so, as that same me from replacing the evap canister.......
