Power window problem
My 2005 RX330 has a window problem. Only the driver's side opens. I thought it was the window lock button gone bad so I replaced the driver's side switches. Wasn't that. My next guess is a fuse. Any idea which one, or if it isn't that, what could it be? The power mirrors adjust but the power door lock doesn't.
Thanks
Thanks
Thanks
Thanks
Margate330 (04-10-21)
Agree with Vincenze, go around to each door and use the switch on it to lower (all the way) and raise the windows. This is so the switch panel on the driver's door can "learn" the other windows. I'm not sure how it learns but it works! I don't think you have to hold each switch down for 30 seconds though but YRMV.
Bob
Bob
Thanks
Thanks
I can only open each of the windows from their respective switches only. One the driver's side master panel only the driver's window works. The master lock also doesn't work. I tried the opening each window from it's switch, they worked but the master switch still doesn't work.
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1018x540/image_6a99401c44b575bde23a4fb41cecde6a998afac3.png)
UPDATE: Tried all suggestions. All windows work from their respective switches. Automatic up and down works on all. Only driver's side window works from driver's master switch. Really stumped.
sounds to me like its the master drivers control panel thats the culprit. Thats the issue on my rx as all my windows will open at each door and the control panel except the right rear one wont open from the control panel. My indy shop down the street confirmed its my drivers panel thats the culprit so I would try replacing that on yours.
I'm sorry, I'm having a hard time following along.
>> Please confirm/correct below as needed for a logical approach and add any extra details that seem relevant to help us understand better what you have going on.
Driver Side Master Switch
Locks driver side door- yes
Locks all other doors- no
Operates driver side window- yes
Operates all other windows- no.
Does the master switch have seat memory buttons and do they work(m1, m2)- ???
Using the key in driver side door
Will operate all windows up & down- ???
Will lock and unlock all doors- ???
Driver side master switch replacement:
Replaced with new oem- ???
If replaced with used was it confirmed to be a "working unit" by seller and we know for a fact it isn't faulty- ???
PS- The driver side master switch contains a computer module that communicates to other modules located inside all the other doors for windows & locks. The body ecu is also involved so more info is needed to have a chance moving forward.
* Window fuses can prob be ruled out since each window has it's own fuse and OP says can roll down independently.
Hopefully others have more to add...
Locks driver side door- NO
Locks all other doors- NO
Operates driver side window- YES
Operates all other windows- NO.
Does the master switch have seat memory buttons and do they work(m1, m2)- ON DOOR. NOT WORKING
BUTTON TO DISABLE ALL OTHER WINDOWS WORKS
Will operate all windows up & down- ???NO
Will lock and unlock all doors- ???NO
Replaced with new oem- NEW BUT NOT LEXUS OEM
From your reply of what was workng and what was not, it looks to me like either 1) the data communication was cut from the master switch to the Body Ecu(mpx wires) due to bad plug, harness, etc) or 2) new master switch is faulty(it can happen) or 3) the Body ECU has failed or 4) as you just proved- the master switch's commands were being ignored by the Body Ecu until the battery cable reset/re-initialize.
PS- the child lock button does not go thru the body ecu as far as I know.
