New front brakes with grapping noise when shifting to reverse for drive
If that is a front wheel and the picture is the top of the caliper bracket, the spring loaded clip is missing or installed at the bottom. Look again at my picture and you can see the rounded shape at the side or the pad, it snaps onto the pads edge and provides downward force on the pads while in the bracket to prevent them from shifting back and forth during braking, when you do a direction change and hit the brakes in reverse, the pads shift in The bracket and collapse the spring force of those clips, causing a clunk or metallic click. If you put the clips at the bottom, every time you apply the brake in forward gears the pad will have to compress the clip and a light metallic clunk will be heard, check to see if the clips are at the bottom as opposed to the top, it’s not uncommon for the error to occur, I’m not slamming your mechanic by any means, I’m just pointing out that in your picture there is no clip on the side of the pad which looks to be oriented to the top in your picture.
TOP of pad front passenger side.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/dsc00655_8c132863e9756404488708a1afb1eee08bc7e66b.jpg)
BOTTOM of pad front passenger side.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/dsc00656_cd4764681b9e0394be3de3a47e86aa79fbe00566.jpg)
Notabot10
09-30-19 06:42 PM
