It could be something with the rear wheel speed control sensors. Check the code to find out if you are dealing with the left side or the right side of the car.
C1784 Right rear speed sensor circuit malfunction -
Skid control ECU (Brake actuator assembly)
Suspension control ECU
C1785 Left rear speed sensor circuit malfunction -
if it IS related to speed controls....do you have mismatched tire sizes? Like new tires in the rear and older tires in the front? if so rotate the tires and see if it goes away
