Anyone use these filters???
Hi guys, so today i wanted to check out another parts place. I went to a local Napa shop. I picked up a cabin air filter and wanted to get an oil filter. They had a regular (pro select) and their gold line of filters. It seems to be made well. I usually buy wix, which have worked well for me.
any of you use this brand before?
i also change my oil every 6000km.
fab
fab
I prefer OEM Denso filters, but you can't go wrong with the Napa Gold -- it is made by Wix and is the same filter.
https://www.fleetfilter.com/comparis...LD-filter.html
JimmyRX350 (08-31-21)
Cdnewton... after i posted this i read a bit more on it, seems like they are wix. I went with the regular filter, not the gold. Is it still just as good as the wix brand grade?
i was reading more about the Spin-on type filters. My lexus uses the round, paper filter. I guess it's more simple compared to the spin-on types?
hopefully the one i got will work well?
fab
fab
from Wix: The Proselect filter is manufactured by Wix Filtration Corp. The Proselect filter is manufactured to very different standards; Wix says it traps 50% less dirt than their standard filter, and recommends an oil change interval of just 5000 km with the Proselect
Cdnewton... i took a look at the proselect filter and compared it to the Wix one i have. I counted the pleats in both. The proselect had 42 while the wix had 44...isn't that kinda close? Is it a big difference? I know the filters are different for the spin on ones (material and metal housing, oil seal), i figure with these filters being just paper, should be ok?
as i said, i change my oil about every 5-6000 km (about 4000 miles). Will the proselect be ok?
fab
fab
JimmyRX350 (08-28-21)
Just looked at the napa site, and saw the proselect Master Pack filter i got. It says oil change intervals should be around 8000km. I change mine at 5-6000km. I guess it should be fine?
Hi friends, I buy mine oem on ebay in 3 or 5 pack quantities very cheap and keep them on the shelf for when I need them.
I just recently realized you use the cartridge type filter on the RX350 while mine is a spin on type on my RX330 but I found these
today and just wondering why not use oem or are they not as good?
The following 2 users liked this post by Lexuswiz:
Margate330 (08-28-21),
spinellib (08-29-21)
Great...
So they are copying oem oil filters too... Thank you for the heads up.
Only asked about oem because I always wondered if they were any better than Wix or other aftermarket or are they cheap made.
I like Wix, I've been in their factory in Gastonia, NC many years ago and saw filters being made with my own eyes on their machines so I know some of their stuff is made in america and they take a lot of pride in their product.
Yeah, evidently they (china) are cloning Toyota parts boxes, right down to copying the mulit-colored shiny sticker of "authenticity" and printing "Made In Japan" or "Made in Philippines."
That includes brake fluid and transmission fluid, etc., too.
If I buy online, I buy directly from a Toyota dealership or Rock Auto. Ebay is not trustworthy at all, unless you know for certain the merchant is a real Toyota dealership store. Thousands of fake listings for "Genuine OEM" parts. Amazon is almost as bad.
fabchef, I use Toyota parts, but Wix/Napa are certainly better than fake Toyota parts. So rest assured you're using a decent filter.
SJM (08-31-21)
Great...
https://youtu.be/aeqYIt1x7Jw
I agree Ebay can be sketch but I always look up the dealer, typically their username matches the dealer's name then I can google them.
SJM (08-31-21)
https://www.ebay.com/itm/232189821694
The 3 pack Margate found is $6.66 per filter. The 5 pack (with shipping added in) is $5.17 each. I can justify a 5 pack because I have 2 cars that use that filter.
I use Wix xp, Mobil 1 & K&N filters w/ synthectic oil....as those filters are designed for synthectic oils.
SJM (08-31-21)
Wow! I didn't know that there are knockoffs in car parts like that!😧.
i guess it also comes down to what kind of oil you are using, and frequency of your oil changes. I know of people using full synthetic oil and changing it once or twice a year. For me i find that way too long.
I'm currently running Mobil Super 1000 oil, which is rated for 7000km. I change it ever 5-6000km MAX! I find it makes the car run smoother.
fab
fab
