P0354 Ignition coil
You'll be able to get all dealer-service information if you sign up for the "Lexus Drivers" website with the car's VIN.
Just look at Service History after you register.
>>>Is there any harm in just replacing the front spark plugs and coil for now?
I think that's the wise thing to do. Tackle one issue at a time. Fix what you need to do to stop getting engine fault codes.
After that, you can prioritize other issues and work at your leisure.
Luv07RX350 (12-23-21)
I think I've seen 13 ft lbs mentioned here, but I can find it when I search. For the FK20HR11 plugs, Denso cites a range of 15 -22 https://www.densoautoparts.com/spark-plug-installation
I bought my RX used and the first thing I did was look underneath to check the status of the infamous oil cooler lines I've read so much about.
I spent 5 minutes looking because I didn't believe my RX didn't have the oil cooler -- I assumed it was standard equipment on all RX's, regardless of the tow package.
turtlepeas
04-19-20 10:26 PM
cggeo555
GX - 1st Gen (2003-2009)
10-24-16 11:28 AM
