VSC flashing, engine and trac lights on
Hi folks,
My VSC started flashing with engine and trac lights on also. I scanned rhe OBD and shows P0352 ignition coil “B” Primary / Secondary Circuit code.
Can anyone please instruct me how to fix this issue. I know it’s one of the ignition coils, however, I don’t know where to start.
I’d appreciate all the help in advance.
Thanks!
Boyzky 350
Thanks!
Boyzky 350
Lucky, cyl #2 easy to get at: may want to post your model and year, 3.3 or 3.5 engine, they are different, though maybe not for this:
See: https://www.clublexus.com/forums/rx-...ode-p0352.html
I had a cylinder 2 misfire code, after checking several ignition related items,it turned out being a Bad Gas Cap, Bad check valve inside the gas cap allowing unmetered air into the upper intake manifold plenum
BTW, I had the same lights come on
Richardsr
12-16-21 06:44 PM
