RX350 P0365 start and die
I was trying to do some maintenance, replacing bank 1 plugs. Ended up pulled wires out of the cam position sensor. I then replaced the wire plug, once all back together it starts strong then immediately dies and throws P0365 code. I did pull the sensor, do I need to replace sensor now? Any ideas? Thank you all.
Yes
Camshaft Position Sensor harness is open or shorted Camshaft Position Sensor circuit poor electrical connection... did you re solder wires in connector
Read more: https://www.autocodes.com/p0365_lexus.html
Yes, I soldered the pig tails from the new plug to the harness, then heat shrink I could go back in to make sure there is nothing grounded/shorted but I'd be surprised
Thank you for your reply
s
Read more: https://www.autocodes.com/p0365_lexus.html[/QUOTE]
s
woodfam528
03-11-22 11:19 PM
