New Rotor Thickness
Recently when my 2008 Lexus RX350 went in for a change of all fluids, the report that came back said that my brakes were okay and that I still had 5 mm on the front rotors and 6 mm on the rear. I had asked for the measurement since I was replacing the brake fluid and didn't want to do it twice if I needed a brake job. I forgot to ask what % of the rotors are remaining. Does anyone know what the thickness of new rotors should be? Thanks, Bob.
https://www.rockauto.com/en/moreinfo...438207&pt=1896
https://www.rockauto.com/en/moreinfo...t=1896&jsn=435
Minimum thickness is used when resurfacing if you're below the minimum you have way bigger problems.
I'd add, best to flush your brake fluid when you do your brakes......
