F-Sport Pedal Install
PART NO. LIST:
- Accelerator assy: 78120-30A30
- Accelerator pad: 04000-14253
- Brake pedal pad: 47121-53010
I really like the pedals in my '14 F-Sport and I wanted this same setup in my '08 base. I recently did the swap on my 2002 Highlander but it was easy due to the accelerator pedal not being a whole plastic assembly, the solution would be to get one from a different model - but which one?
First, I tried one from a RHD RX300, the pedal was WAY too far to the right and would basically be rubbing the interior panel, not safe at all. Next, I tried part number: 78120-30A30 from a GS350. This ended up being the ticket.
![](https://www.toyotanation.com/cdn-cgi/image/format=auto,onerror=redirect,width=1920,height=1920,fit=scale-down/https://www.toyotanation.com/attachments/53d1b6d0-9bda-4794-a28f-c653e0e8986a-jpeg.378749/)
![](https://www.toyotanation.com/cdn-cgi/image/format=auto,onerror=redirect,width=1920,height=1920,fit=scale-down/https://www.toyotanation.com/attachments/5754a001-43a8-45fa-850f-54c9afbccbaa-jpeg.378750/)
![](https://www.toyotanation.com/cdn-cgi/image/format=auto,onerror=redirect,width=1920,height=1920,fit=scale-down/https://www.toyotanation.com/attachments/cd4f7717-9476-458f-83dc-e559a9e124cc-jpeg.378789/)
![](https://www.toyotanation.com/cdn-cgi/image/format=auto,onerror=redirect,width=1920,height=1920,fit=scale-down/https://www.toyotanation.com/attachments/441df180-6767-4833-82d4-5d1471d2b326-jpeg.378791/)
Overall, I am very pleased with how the install turned out and it didn't cost very much either. Something to note: You will need to trim the accelerator metal shaft to sit flush with the new style F-Sport pedal as it sits higher due to Toyota's floor mat lawsuit. If you use an old IS300 one, this won't be an issue.
Cross-posted: https://www.toyotanation.com/threads...#post-14615906
Sybaritic
05-30-17 08:44 PM
