2007 RX350 - Ignition Coils
I am looking at an error code P0352, and from the looks of it I have a faulty ignition coil in my #2 cylinder (front passenger). I figure with 148k miles and having just purchased the car, I would change the plugs and then look at the coils. Here is the question... I can find coils at $100 for six and I can find Lexus oem at $150 for one. I dont want to cheap out and have to redo things but I also dont want to spend $150 for a single coil. I was thinking of just changing all of them but maybe that is not the right idea either. Any comment from people with some experience?
Thanks!!
Thanks!!
Put a coil from a different cylinder into #2 see if the problem moves with the coil. 6 coils for $100 is too good to be true there is no need to replace all of them if one is bad.
machew (04-13-22)
Appreciate the comment!
The following 2 users liked this post by Mesquite77:
machew (04-13-22),
Margate330 (04-13-22)
Thank you for the reply. I will give an update to my problem later today. I switched #2 with the #4 cylinder and will see what code it is now throwing.I dont have a code reader, so I'll swing by my local Autozone on my way home.
So, I was on my way to get my codes read again after swapping my #2 and #4 ignition coils. I get halfway there and the check engine light shuts off. What the heck... I don't know if I have a question or not but I found this strange. I guess I will just wait to see what happens.
Buy a $35 code reader it will be good enough for your purpose. There may be stored codes or as above a flaky connection you "cured" by moving the coils around.
machew (04-13-22)
I'm going to replace the spark plugs soon... so until then I'll just drive it and see what happens.
Appriciate all the replies from everyone. I dont really have the money to take it to a shop right now.
You can replace the connector housings look up 90980-11885
Rears don't seem to get so hot.
Plz can I recommend getting your own scanner that will read codes and live data if you want to save money and have convenience, you won't regret.
Back at it today... I was code free for a few days and the codes came back and in full force.
c1201, p0354,
p0306, 05, 04, 03, 02, 01, 00
I bought new spark plugs to start... any new idea?
c1201, p0354,
It looks like you just confirmed you had a bad #2 Coil, which you then switched to #4.
Isn't that what you did, switch the coils?
I think if you replace that ignition coil, all your codes will disappear...until another coil fails, which they will eventually because they're all the same age/miles.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x772/20220415_200936_3412574a1ff85bcf7e9509db1a4a7c8da715dd89.jpg)
