Power steering rack isn't tightly bolted in
10th Gear
Already great posts for ideas.
Can't help but to think you got a half hearted answer from the alignment shop cuz how can the rack be loose if you say the bolts are tight?
If rack bolts are tight there is something else going on as suspected by members above.
In addition to what's already mentioned, did anyone make sure the mounting holes for the reman rack fit the bolts properly without slop.
Just throwing out another idea to add to above for brainstroming...![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
If you want another thing to check, check the steering column u-joint that connects the column to the rack. If that is out of adjustment, it could cause a popping sound.
10th Gear
Msaucier
Performance & Maintenance
02-06-16 04:47 PM
