alternator swap
alternator swap
i bought a used 2007 rx350 that originally had the tow package [it's no longer used for towing], so i assume the alternator is the 130 amp. can i replace it with the original 100amp? i'm wondering about wiring connectors etc? any advice is appreciated.
the alternator is on the top side of the engine on the passenger side. Right in front of the timing belt cover. Below it is the ax compressor.the same belt goes over the outside crankshaft harmonic balancer pulley the condenser and the alternator. The alternator is the most north component on thag belt line.
I just changed the alternator on my '08 RX350. On a difficulty scale of 0 to 5 it was a 4, fairly difficult. Saved $700 so it was worth it. If you are good w auto repairs, go for it, it you are focused on looks and bling, pass.
Doggn8
02-27-20 12:47 PM
