Just bought an 09 rx350 with 100k its intermittantly throwing P2714 Code: Pressure Control Solenoid “D” Performance / Stuck Off, has all the symptoms.. ive read that a fluid flush could fix the issue..has a flush worked for anyone? If I replace the solenoid which one is it? There are 6 And has anyone had success with the Chinese solinoid packs from eBay? Thanks
Just bought an 09 rx350 with 100k its intermittently throwing P2714 Code: Pressure Control Solenoid “D” Performance / Stuck Off, has all the symptoms.. ive read that a fluid flush could fix the issue... has a flush worked for anyone? If I replace the solenoid which one is it? There are 6 And has anyone had success with the Chinese solenoid packs from eBay? Thanks
Since the problem is intermittent, I would do the flush. Since the car is low mileage and was probably used for many short trips where the engine and transmission could never fully warm up. Fresh transmission oil will remove the varnish that builds up and causes things to stick.
