3MZ-FE engine Valve Cover Gasket replacement
Just did the valve cover gasket replacement on 3MZ-FE engine on 2004 Highlander,
where same engine is used on 2004-2006 Lexus RX330, and 2005-2009 RX400H.
While I had everything open, I did more work.
This was not a quick DIY and had many challenges, but I'm so glad to be done with this.
1. Replaced valve cover gaskets
2. Replaced spark plug tube seals
3. Replaced spark plugs
4. Replaced PCV
5. Replaced fuel injector O-rings
6. Replaced broken connectors
7. Replaced broken EVAP hose
8. Cleaned intake valves
9. Clean MAF & TB
4. Replaced PCV
9. Clean MAF & TB
The following 2 users liked this post by CowBoE:
Margate330 (12-12-22),
MattRX (12-12-22)
Nice DIY, thanks for posting! Reminds me of the fun time doing it on my 2002 Highlander, and the even worse time on my 2008 RX!
I said no thanks, and that this is a good one time challenge/experience for all hobby mechanics to go through. LOL
MattRX (12-12-22)
It can be intimidating for DIY or for the first time pulling the manifold but like you say, after getting that experience it's a breeze.
I don't know about you but removing and replacing the rear valve cover is tight back in there for me, almost no room.
When I watched other videos, I was thinking how hard that can be...
and while doing the work, I was like, may be I should've just paid to get it done. LOL
Looking back, really the only hard challenge is removing and re-installing the rear valve cover,
rest are just removing bunch of bolts, hoses, and connectors and keeping removed parts/bolts well organized.
CowBoE
02-23-23 01:59 AM
murphysf
RX - 1st Gen (1999-2003)
04-13-19 09:32 AM
