2004 RX330 alignment specs
2nd gear
I’ve had my RX330 aligned but still not driving right. Still feels out of alignment. FWD model. Can someone tell me the alignment specs for this vehicle so I can confirm the shop aligned it to spec? Thanks.
FRONT SUSPENSION
Toe-in (total)
0° ± 12' (0° ± 0.2°, 0 ± 2mm, 0 ± 0.08 in.)
Rack end length difference - 1.5mm (0.059 in.) or less
Wheel angle (AWD)
Inside wheel - 35°41' ± 1°30' (35.68° ± 1.5°)
Outside wheel: Reference - 31°22' (31.37°)
Wheel angle (FWD)
Inside wheel - 35°28' ± 1°30' (35.47° ± 1.5°)
Outside wheel: Reference - 31°13' (31.22°)
Camber
AWD: -0°35' ± 45' (-0.58° ± 0.75°)
FWD: -0°40' ± 45' (-0.67° ± 0.75°)
Right-left error: 45' (0.75°) or less
Caster
AWD: 2°30' ± 45' (2.50° ± 0.75°)
FWD: 2°45' ± 45' (2.75° ± 0.75°)
Steering axis inclination
AWD: 10°35' ± 45' (10.58° ± 0.75°)
FWD: 10°45' ± 45' (10.75° ± 0.75°)
REAR SUSPENSION
Toe-in (total)
0°18' ± 12' (0.3° ± 0.2°, 3 ± 2mm, 0.12 ± 0.08 in.)
No. 2 lower suspension arm length difference
AWD: 1.0 mm (0.04 in.) or less
FWD: 1.5 mm (0.06 in.) or less
Camber
AWD: -0°40' ± 45' (-0.67° ± 0.75°)
FWD: -1°20' ± 45' (-1.33° ± 0.75°)
Toe-in (total)
Wheel angle (AWD)
Wheel angle (FWD)
Camber
Caster
REAR SUSPENSION
Toe-in (total)
Camber
Did the shop check the suspension & tires for correct pressure & wear? I'd think they would, thou......Whats the alignment print out say?
