New Low-Beam Headlight Replacement Issues
2nd gear
One of my Adaptive Headlight LED bulbs blew. When I started to replace, I noticed that apparently the previous owner had removed the OEM Halogen bulbs then spliced in replacement LED 6000K bulbs. These bulbs and adaptive movement with the steering wheel worked fine for many months after I purchased the SUV. So I purchased similar LED 6000K bulbs and the new bulbs are too dim and my Adaptive lights do not move with the headlights anymore. Also, my AFS dash light flashes consistently.
Anyone ever experienced this before and have any suggestions? Thank you in advance!!
Sorry there's so much unknown conditions on your situation. However if tis happened to me, the 1st check I would do is check if the wiring that you made are tight, secured and insulated and also check if the wirirng is obstructing the movement, good luck.
2nd gear
I checked the wiring connections and insulation, and for restrictions with the reflector housing by the wiring / ballasts inside of the low-beam areas and they both are fine.... still have the same problems but I really appreciate your suggestions Mandyfig. Thank you so much!!
If anyone has more suggestions, they would be greatly appreciated!!
bladest
09-12-22 10:45 AM
BrownGuy51
RX - 3rd Gen (2010-2015)
07-27-22 06:56 AM
