park assist alarm
1st Gear
Hi all,
I'm a new subscriber. I'm having an issue with my park assist alarm and I'm hoping someone might have a solution.
When I put my car in reverse the park assist alarm goes off in a steady beep and the display seems to shows the issue is below the rear of the car.
The sensors are clean and I hate go out and buy new ones if that is not the problem.
You may need to get your sensors scanned to determine if one is damaged and needs replacement. Try going to a body shop as they deal with damaged bumper sensors all the time.
If you have a hybrid RX450h then constant beeping when backing up is normal. Lexus put that warning in to make sure you know that you are in reverse gear.
