2013 RX350 Roof Panel Noise
Has anyone experience any sort of noise coming from their sunroof?
Sounds like a knock or something similar coming from like up above.
The only noise I have observed is the inside slider moves couple of mm from fully closed and a gentle push back to fully closed takes care of it. Slide back happens due to vibration and inertia. You may like to add a bit of soft padding to increase friction.
Apart from that, you may like to fully open and see if a leaf or something has worked its way in or any spring may be loose.
Salim
Salim
SDUteFan
08-10-17 07:16 PM
