Part number for 2015 RX 350 headlight Leveling sensor
3rd Gear
Hello,
I would like to request some help finding P/N or a Toyota cross reference for the parts number for the sensor only on a 2015 RX 350 headlight Leveling sensor. The only thing i can find is for the complete assembly. It $400.00 and has a two month delivery. Please advise.
Welcome to CL. Do you need the sensor on the rear axle or for one of the headlights themselves? What is the problem or what broke that needs repair?
You can go to one of the online OEM Lexus parts sources, enter your VIN and search for the part. A few popular sites are MyLParts.com, LexusPartsNow.com, or Lexus South Atlanta Parts.
There have been some prior threads on this that may contain the information:
https://www.clublexus.com/forums/rx-...ng-system.html
https://www.clublexus.com/forums/rx-...d-threads.html
https://www.clublexus.com/forums/rx-...ht-sensor.html
https://www.clublexus.com/forums/rx-...ment-help.html
3rd Gear
I need the part for the rear axle. I do not need the whole assembly. I just need the sensor. ( I have the warning on the dash display of Check Headlight Leveling sensor)
There are some on ebay (I searched 2011 Lexus RX 350 headlight level sensor ) https://www.ebay.com/sch/i.html?_fro...ensor&_sacat=0
You never said what the issue is with your headlights. Are you positive this is the part you need?
Did you see this related thread? https://www.clublexus.com/forums/rx-...-location.html
It will fit, see below for info from Rock Auto. Lexus made no real mechanical changes between 2013 and 2015, just some software etc.
Of course you could look at or photograph yours and compare it to the ones on ebay.....I noticed most of the ebay ones say they fit the rear left. The Rock Auto one is rear right.
I think rear right is what is needed.
Or cross check the part number to see what other models it fits.....
However I did that for you a different way..
Here is an aftermarket one from AISIN (who is an OEM supplier - so high quality) at Rock Auto for under $200 and they state it fits the 2010-2019 RX. If you use this link then click on the part number next to it and the little box next to the number you will learn this stuff.
https://www.rockauto.com/en/catalog/...t+sensor,17137
