Nav monitor problems
Welcome everyone. I ask for advice. I have a rx350 2010 with navi. in cold weather, the screen does not show well. flickering blinking. When heated for 45 minutes, stops. everything is in order. In summer tare 10 15 min. all functions work always. camera menu etc. when ingnition stops, its start again but short period 5 min. I have two RX 2010 but the second one doesn't have Navi. I'll want to try changing the radio. whether it is suitable for testing. monitor wiring clean ,mouse cleaned ,. Thanks for the advice Regards
Pic
Your screen may just be going bad or it could be some circuit inside the audio system. You can probably find a used one on eBay or a junkyard. I would consult with an independent car audio specialty shop for a diagnosis confirmation before replacing parts.
When I was a kid our next door neighbor was a TV repairman, back when they actually repaired those big old tube TVs. He worked out of his house. I recall watching him do diagnosis on a TV that had a bad picture until it warmed up by selectively spraying components with a freeze spray to find out which one was failing when it was cold. You can buy electronic freeze spray on Amazon.
I welcome everyone, I decided to change the display because mine is flickering. There are several types on sale. Made in Japan and assembled in Usa Japanese 2012 ??
will work, for 2010. Thank you
jrmckinley
11-08-18 05:53 PM
