Oil drain screw looks different
I always use a manual vacuum pump to extract the sump oil from my RX.
Inserted down the dip tube, it works fine, removes all the oil and is much less messy than dropping the sump plug.
Last time I did an oil change using the pump, I removed the sump plug afterwards as a "peace of mind" check and no oil came out, so the vacuum pump works as designed!
If you rack on miles at a fast rate, vacuum pump may be good enough. But once a year drain the oil through the drain plug. YMMV
Salim
Pulling the drain plug and tilting the vehicle back(lifting the front end) is the easiest and best method to drain out most of the oil in the pan since you have to crawl under the car to remove and drain the oil filter anyway.
Again, both methods will work just fine. I use the top down suction method for my gas powered lawn mowers oil changes.
John7 (06-25-23)
vadimfrey
RC - 1st Gen (2015-present)
03-09-22 11:47 PM
