Brake pedals low after brake fluid change
Sounds like air in the brake system. A common mistake is to allow the brake fluid reservoir to run low during a fluid change; which allow air into the ABS module. I believe that you(or mechanic) may need to use a scan tool to bleed the ABS module and then bleed the brake lines again.
Clutchless (03-11-24)
If after a few times of braking [not pumping] the pedal does not bottom out where you are used to, there can be a problem. There is definitely a problem if the brakes feel spongy [air in the system]. Although Lexus publishes the range of acceptable clearance from floor to bottom of the brake pedal when pushed down [with assist], a quick test is that your left toe should pass freely under the pedal.
Salim
Salim
Salim
Salim
Spongy and holding [not dropping] means air in the system. You might need brake servicing tool [this modulates the valves in ABS system to open up chambers to purge air completely]. I think you may not be able to DIY it. I would look for Toyota/Lexus repair shop.
Salim
Salim
Salim
Salim
MarkMV (03-17-24)
