Transmission Issue
I think most would agree to have the ATF checked immediately, if not sooner.
gel937 (04-14-24)
If you have no option but to keep, then let the tech make the choice but I recommend against a flush, There is plenty of discussion on this topic.
I am a bit surprised that 1st to 2nd shift is at 20mph. I would have thought that due to economy the transmission would shift sooner. Only bringing it up as t it seems odd.[ I have the hybrid, which has a different transmission].
Salim
gel937 (04-14-24)
I recommend that you try to change your old transmission fluid and add a anti-slip additive to account for a worn transmission clutch, because sometimes just adding new OEM like fluid without any additional friction compound can cause a transmission to slip even more if the clutches are very worn. I would use Valvoline MaxLife transmission fluid because it already have the anti-slip additive mixed into the fluid in the proper ratio.
gel937 (04-14-24)
