2012 Lexus RX350 wheel upgrade
2nd gear
Looking at a nice set of LX470 285-60-18 chrome wheels..
will these fit on my 2012 RX350 without rubbing inside the wheel wells??
Thanks
Thanks
carguy75 (04-27-24)
The offset of those wheels is 58 mm and will not work with the RX which as a 35 - 40 mm offset. The LX is built on a different platform that is not compatible..
Wrong tire size and I agree that Chrome is a terrible wheel choice as it falls apart and they weigh much more than normal wheels.
However, wheels from the following Lexus and Toyota models that are built on the same chassis platform as the RX will fit perfectly: ES350, NX, Camry, Avalon, Highlander, Sienna. There are many used sets available on eBay or Craigslist or Marketplace.
2nd gear
Thanks for the info everyone!
My old 1999 Lexus ES300 had beautiful factory chrome wheels but after several years later they did develop air leaks around the tire bead.
The tire store dismounted the tire(s) and wire brushed the bead but that never lasted very long either,
i eventually put tubes in several of the tires in order to eliminate the air leaks.
I would avoid the chrome wheels due to possible corrosion that will cause the plating to peel under the tire bead and the wheels may start to leak if not already. Many modern OEM wheels uses a chrome like PVD finish that does not peel away like chrome. I am not sure if the Lexus LX470 wheels are chrome or PVD finished.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
