How to fix-P0713 Code
2013 Lexus Rx 350 I'm Getting The P0713 Code Which Is Trans Fluid Temperature Sensor A Circuit High Input Don't Know Where To Start, Anyone Had Similar Issues, Any Solutions ?
Welcome to CL. How many miles are on it? Has the transmission fluid ever been changed? How does it operate now and is it different than before you got the code? Did you get a warning light? Or was it acting up and you scanned for codes?
I found this quickly:
P0712 Transmission Fluid Temperature Sensor A Circuit Low Input 1. Short in ATF temperature sensor
2. Transmission wire harness
3. TCM 79 ohms to 156 Kohms
P0713 Transmission Fluid Temperature Sensor A Circuit High Input 1. Open circuit in ATF temperature sensor
The component contains both the temperature sensor and pressure sensors, and is an internal part near the valve bodies, which means you are likely to have other internal issues and may have to decide how much you want to spend to fix or replace it
https://maktrans.net/modul-provodki-u660e
See this for more information: https://www.transmissiondigest.com/t...switch-issues/
This guy shows how to replace it but does not really speak English. It is not much worse than replacing the trans filter. However your trans may have other internal issues.
Curated Content Editor
RX - 4th Gen (2016-2022)
11-20-19 06:17 PM
