2010 RX 450h rear suspension help
Old 07-29-24, 10:09 AM
Woolbury
1st Gear
Woolbury's Avatar
Default 2010 RX 450h rear suspension help
Hi there! I've been driving my 2010 RX 450h for around 8 years, and while I was changing a tire yesterday, I discovered some problems with the rear suspension. I'm not sure what the specific part is called, so could someone guide me on how to replace it?
Old 07-29-24, 03:32 PM
Clutchless
Clutchless's Avatar
Received 1,193 Likes on 1,020 Posts
Welcone to CL. If you did not know that that item is the spring, and that the upper spring mount appears damaged, then you should not attempt any repairs or further inspection of it yourself.
You probably do not have the tools or high level skills to deal with replacing a spring or diagnosing exactly what is wrong. Your single photo is insufficient for diagnosis. You need a shop to determine why the upper spring mount appears to be out of place. I would find a local independent shops that works on Toyotas. Try Google or Yelp for reviews. I would not take a 14 year old car to a dealer. They will make up some very expensive repair to scare you into buying a new car.
Springs can be quite dangerous due to the pent up energy. When parts are separated, you could be injured or worse. Do not try to take it apart yourself.
Are you in the rust belt? Has it been in an accident? Was it a simple flat tire, or did you hit something on the road that may have caused this damage?
lexusisgs
RX - 3rd Gen (2010-2015)
13
05-27-23 08:58 PM
BobThorton
15
06-15-12 08:40 AM
rominl
36
11-30-09 05:58 PM
kickin8
01-14-09 09:48 AM
Quick Reply: 2010 RX 450h rear suspension help
