Trailer hitch on RX350
Has anyone installed a hitch on a 2010 RX yet? I received mine from Curt and tried to install it today, but I had a problem removing the lower fascia under the bumper. There are 13 fasteners and 11 are no problem, but there are two unusual fasteners near the exhaust pipe that I can't figure out. They look like a large black rubber washer with a cross in the middle. I tried unscrewing them without success. I'm afraid to pry them loose and possibly ruin them. Has anyone seen these fasteners before?
Finally crawled under the car to see what you were referring to: I can unscrew them partway until it clicks. Still being retained somewhat by a tab...don't know if you stick a screwdriver into the space between the washer and the plastic to push in a tab or just pop it off. The screw that it's anchored on comes from the floor of the cargo area...doubt you unscrew that. Since I don't have the other 11 fasteners undone, I didn't have enough play to just pop it off. Hope you figured it out by now anyway, and if so would like to see pics.
http://www.netshops.com/images/pdf/CTM1268.pdf
I haven't checked in for awhile, but I called Curt (hitch maker), and they told me the two problem connectors needed a quarter turn to disconnect. (kind of like Danish furniture) This didn't work, so I just pried them loose without damage. Otherwise installing the Curt hitch was pretty simple. I purchased it at TheHitchStore.com, for $153 and free shipping. This is a high quality product and better than the Valley hitch I had on my MDX. I don't know what the dealer charges, but I am sure it would be much more.
Glad to hear you got it installed. Was the wiring difficult? I've seen alot of Curt hitches on Toyotas in general. I have yet to see a 10RX with one...got pics?? Do the instructions that come with the hitch describe the wiring satisfactorily? I assume you had the tow prep package already installed? Thanks for any info...contemplating it myself now.
I will can post a picture of the hitch installed later, but it is very inconspicuous ... doesn't take away from the rear of the vehicle at all!
Oh yes, please post pics. Based on the link from a previous post, it mentions cutting the fascia...did you do that and with what tool, dremel? box cutter? Trying to get all the info I can before taking the plunge. Was an engineer by training, but somehow, when it comes to my own cars, stuff takes twice as long
Just ordered the complete kit from etrailer.com. They advise that the hitch is in Canada so should delivered to me in Ontario with great dispatch and no customs hassles... I will post how it all worked.
In perusing the install instructions, the hitch itself seems quite simple... looking for comments on the electrical part of it.
Thanks in advance
Bill
Thanks in advance
Bill
Hitch report
Curt Hitch, draw bar and pin delivered within 24 hours (pretty nice for us Ontario folks). Install took a lazy 2 hours without any help. No big deal, everything fits, cut the fascia with a jig saw and adjusted with a box cutter. The only minor issue was the front, right weldnut was slightly miss-aligned on the rail and took a little work to get the bolt in. Of the 13 fasteners, one pop fastener is hidden behind the mud flap on the left side. Needed a trouble light to see it but all in all this was minor. Good idea to keep track of where the screws/fasteners go as there are few different lengths/types. My suggestion to save time is get a piece of cardboard .... poke holes and install the removed fasteners in said holes in a fashion that will make it clear where they go on the car.
While under there I see there is an electrical connector on the left side up under the fender fascia... hoping that is for the trailer wiring.. if so that will make it easy when I do get the wiring harness from etrailer.com.
Piece of cake, easiest $700 I've ever saved!
Bill
Bill
Hi Bill/All
For those who have installed the Curt hitch, is it only for the AWD model or have some of you installed it on the FWD?
Any photos of what the finished product looks like would be appreciated.
Thanks.
--Nate
Thanks.
--Nate
Bill
Hitch report
Bill
Bill
