ASL on Levinson
Hi Guys..
Just wondering if you can adjust the sensitivity of the ASL on the Levinson system (or any 2010 RX for that matter).
I sat in a friends Scion the other day and you could adjust it "Low" "Medium" and "High". Was nice as sometimes the ASL can be annoying.
I was just wondering if this can be adjusted in the RX's 30 some user settings.
TIA.
--Nate
TIA.
--Nate
Hi Guys..
TIA.
--Nate
TIA.
--Nate
You can enable it or disable it and I believe that's it. You cannot adjust it any other way as far as I know. I wish I could make it a bit more sensitive since I don't think it adjusts the volume high enough when traveling at high speeds and there is more road noise, etc. IF there is a way of adjusting the sensitivity, that would be a nice feature.
Bummer.. Maybe because the Scion uses Pioneer and it is option built in to that brand..
I sure wish they put that option on the new RX's because sometimes the ASL distorts stuff way too much. On our GS and IS it was either on or off also.
--Nate
--Nate
Yes, I found it annoying to have to set each and every source to whatever I want. But then again, you'd only have to do it once for each source and that's it... Unless you disconnect the battery for some reason, I guess.
peteronyc
07-24-10 12:25 PM
Mdkellys
RX - 3rd Gen (2010-2015)
32
01-21-10 11:35 AM
