A/C - no button on dash?
Old 06-17-14, 09:59 AM
  #31
kitlz
No, I don't play soccer!
kitlz's Avatar
You have to call Tesla climate control assistance, LOL! Great car but I don't know how I'd like having that big screen in my face for everything.
  #32
Marqevans
Marqevans's Avatar
Yes, there is an older message thread on this same issue. A button would be much better.
Old 06-17-14, 10:06 AM
  #33
HarryFrank
HarryFrank's Avatar
Better, safer than using Remote Touch joystick, and when turned off, we'd save some gas $$ -- like when it's 63 degrees outside and you just want some fresh air without opening windows at 65 mph.
Old 06-17-14, 10:42 AM
  #34
Cruiter
Cruiter's Avatar
Same thing most of us do, hit 'Auto', then adjust temp year round as needed. Not sure what the fuss is unless I missed something. I think it's the easiest system to manage I've ever owned.
Originally Posted by kitlz
^That's what I do too. I also use the temp adjustment buttons to make any changes depending on how hot or cold it is in the cabin. Works perfectly fine for me.
Old 06-17-14, 12:27 PM
  #35
markrivers
markrivers's Avatar
I think i have to give a little example
It seems " putting it on Auto " DOES NOT give justice to how wonderful AUTO really is
And some members are not getting thr REAL picture or stuck with their old ways.
I have my temp set to 74 and AUTO is always ON ( just like AUTO headlights, BSM, parking assist etc)
When outside temp is 85, i feel the aircondtioner right away with no outside Air
When outside temp is 61, i feel the heater comes on right away
When outdide temp is 74/75, it's outside air that comes in
The system is smart enough to adjust the direction of the vent.
Even if you have left the system ( face/head direction)
it will shift to ( face and feet) to prevent blowing cold/ hot air directly in your face.
If you want the system to work faster, then adjust the temp using the red/blue buttons.
Old 06-17-14, 12:33 PM
  #36
rxsuperman
rxsuperman's Avatar
I agree with you but some people just don't like to run that AC compressor all the time while driving.....it shouldn't be for economic reason because there is little or no MPG difference with or without compressor running.....I heard its actually good to run the compressor all the time to keep the compressor oil circulating.....so if we can control the temp from the dash, I really don't know what is the concern......
Old 06-17-14, 02:19 PM
  #37
Cruiter
Cruiter's Avatar
Old 06-17-14, 04:12 PM
  #38
HarryFrank
HarryFrank's Avatar
…it shouldn't be for economic reason because there is little or no MPG difference with or without compressor running
I don't think that's the case with the compressor in a home AC unit. i.e., it's more expensive to run the AC compressor than just the fan.
When outside temp is 74/75, it's outside air that comes in…
I heard its actually good to run the compressor all the time to keep the compressor oil circulating…
Curious if either of these statements are documented anywhere or could be confirmed by Lexus tech's? Not trying to be confrontational; just would like to know.
Old 06-17-14, 06:01 PM
  #39
kitlz
kitlz's Avatar
I think keeping the AC helps more with eliminating odor issues. Now I did have the compressor replaced on the 300. It's pretty rare from what I've seen around here. And in my case was covered under extended warranty.
Old 06-18-14, 05:44 AM
  #40
rx300mm
rx300mm's Avatar
First thing I noticed when started driving it, no A/C button I am not a fan of a/c due to colder weather in Ontario but during some hot days (like now) I am flipping screens while driving. I would put it to bad design, there are many useless buttons on dash that they could have gotten rid of and a/c there.
Old 06-18-14, 06:03 AM
  #41
elba123
elba123's Avatar
I just think it a waste to run A/C when I am driving with the moon roof open. In such a scenario, when you want to open and close the moon roof depending on speed, it would be great to have a button instead of having to use the menus.
Old 06-18-14, 09:36 AM
  #42
Marqevans
Marqevans's Avatar
The bottom line is when the compressor is on its using power. If its belt driven its inevitably lowering gas mileage.
Old 05-16-19, 02:46 PM
  #43
VictPatman
VictPatman's Avatar
I total agree with you that the AC On/Off button should be on the dash board, when I brought the 2015 Rx350 last year didn't realized there is no AC on/off button. This is another example for Lexus/Toyota engineer old school design and try everything they can to reduce the cost to change the dash board layout, Also Lexus try to tell the customer what the luxury car it should be, what a joke..
Old 05-16-19, 05:40 PM
  #44
slawless
slawless's Avatar
Did you notice when the defroster is on, even when you split defrost and heat, the compressor is running. The little green light on the display is off but the AC is on. You cans tell it is on by listening to the engine RPM change when you turn the defrost on or off. Also you get condensate dripping from the car. Yes, I know the AC will dry the air for more effective defrosting most of the time. Just don't do it behind my back. The future of highly automated cars.
Old 05-17-19, 09:22 AM
  #45
MellonC00
MellonC00's Avatar
If it worked like this perfectly, I would never use the a/c button. Sadly it does not. Not even close. When the A/C is on, the air blows colder (it's not supposed to) and the temperature on your skin feels colder. Trust me. Mrs. MellonC says so without even my telling her so. It's not like I'm not dreaming this up. In other words, if the temperature is set at, say, 72, whether the the a/c is on or off, a good system should not make the cabin colder at the same temperature setting when the compressor turns on by adjusting internal air mix correctly. Our lovely RX's don't do that. If it did, I'll just have it on Auto all the time, like you suggested above. I hate fussing with climate control stuff.....
For some reason, by the way, GM cars and Mercedes have this down to a science, especially Caddy's.. "Auto" truly means automatic climate control on those cars. So far, I have never driven a Japanese make that is truly auto climate control.
Quick Reply: A/C - no button on dash?
