Rustling noise from driver side window/door area
#31
I loloed and this is where they insulated, between the door frame and door shell. Noise now only happens on bumpy roads
#32
got my rx back from dealer yesterday. said they added insulation inside the door b/c the noise was coming from window track hitting door panel. less than a mile from dealership, i started hearing noise again
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#33
I bought my Japan made 2010 RX AWD with all options about 2 months ago.
I can hear this rustling noise from the drive side door/window area when the road is bumpy (or on any uneven road surface). It sounds like the window is not tightly held in the door panel; so when there's any bump or vibration, the window makes this rustling noise, as if someone is shaking a loose piece of window. It's very annoying.
Have any of you experienced this problem? I'm a little disappointed in Lexus. I still have my 2002 RX300, and it still drives/feels very solid.
Apparently there is a know problem with the brake booster valve rattling whatever that is.
#35
I have inside the top of driver's door near the handle a ticking sound that only occurs when on a bumpy freeway or road. It is very faint but since it's close to my left ear I hear it quite promentently. It could possibly be the window rubbing in the track.
#38
Rattling noise is fixed. There was a "cowell" molding below the windshield wipers that was loose. Noise couldn't be duplicated so I took the service rep with me and sure enough once I hit 60mph there was a loud rattling noise near the windshield. It sounded like the windshield was loose. Happy they fixed it!
