Complaint on the 3rd generation ride
Okay, so after having a 2010 450h for two weeks, I have a major complaint on the ride. My wife has on 08 RX and hers is considerably softer. Every dip in the road is felt throughout the cabin. Smaller bumps and grooves are very smooth. It's actually so bad my wife doesn't want to ride in my car and prefers to take hers when we are together. Unfortunately, I did not pick up on this during the 5 minutes test drive they allowed. It's really sad that Lexus has actually gone to a worse riding suspension. My only conclusion is that they figured if people wanted they softer ride they would buy the air suspention. The problem with that is (to my understanding) you can only buy the air suspension in Japan and Europe.
Only two weeks? Let the suspension “smooth” it-self out over period of time/miles. All new cars will ride little firmer when new but as all components “break-in” it will smooth out the ride. We had 05RX and 10RX definitely rides little firmer but that is the result of many owners complaining about soft ride on gen2 RX. Lexus also incorporated 19’s for those wanting more “sportier” ride. Also check your tire pressure and adjust as needed and give it some time.
What kind of a dealer only "allows" a 5 minute test drive? I have not even purchased one yet, but I have taken two test drives of about 15 minutes each, both around the neighborhood and on expressways. The salesman always encourages me to come back for another drive any time.
I think that the ride quality of my 2010 RX is better than my '07 was, and the '07's ride quality was quite good. And I have the 19 inch wheels. I don't think there is any break-in period for the suspension. Is the ride quality of the 450H worse than the 350?
While I'm here, let me add that I thought the ride quality (and the seats) were improved over my '04 RX.
As for the 450H, the ride quality is different due to the weight of the batteries at the back, and due to a concomitantly different suspension. The car rides like it's heavier than a 330 or 350 because it is. It seems comfortable to me, but it also seems less agile.
I still can't get over the fact that the OP not only was limited to a 5 min test ride, he still bought the car. That's a pretty small sample for a pretty large purchase.
Well, I was lucky to get that 5 minutes Fischer! I went to four dealers. Either they had none to drive or were unwilling to use them for demos because they were flying out the door. This one dealer basically let me take it around the block. I got a longer test drive in the 350, but it seemed to ride better.
Klegrow, did you check the tire pressure after delivery? Sometimes the dealer forget to adjust them, all new cars are delivery to the dealer with tires at around 50 PSI.
The 2010 RX is suppose to ride stiffer to improve the handling, it is still consider a soft rider by most luxury SUV standard. Let the shocks and spring loosen up for a few month and it should get better.
I agree. 40 is too high, but I often find that my car is returned to me with high tire pressure, especially when they have rotated the tires or have been working on the brakes. I guess they figure that air is free (still, but just wait). 32psi all around works pretty well for me, also.
My dealer used to always return my cars to me after servicing with too high tire pressure. I could tell it after driving only 100 yards from the dealership. I think they did that to stop complaints about the TPMS warning light coming on. Anyway, after I registered a formal complaint on one of their service evaluation surveys, they now return my cars with the proper tire pressure.
The pressure is too high. You may get better MPG, but you don't need this since yours is Hybrid.
I think RX suspension is too soft, all gen of RX has the soft suspension.
As for the air suspension, you might get it in '11 or '12. This is Lexus strategies.
I had a loaner for a day and besides noticing it was more powerful and quieter than my '99RX, I didn't think the ride was any better or worse per say. If nothing else, I still felt it has the "Lexus" ride.. smooth and floaty with not great road feel. Then again, I don't need to feel the road, the roads around me stink.
As for pressure, 40PSI is too high. 35 tops I would think, even for 19".
