getting back to the map display
After pressing the menu button and performing whatever item you want to change/modify, how do you get back to the map screen without having to turn off the engine and restart? In other words, if you are on map display while driving and you press the menu button, their does not seem to be an icon to use the mouse and get back to the map display.
Correct! Above the mouse there are two buttons. Left button is 'menu' and the right button is 'map' and it takes you right back to the map screen.
Pretty easy once you get used to it.
There should also be a setting to have the screen auto-return to the map after a certain period of time. It should be under user settings on the GPS menu.
Hope that helps.
Jay
Hope that helps.
Jay
