Foggy taillight.
Foggy taillight.
After driving the car for a day in the rainy condition, my left rear taillight got this moisture problem. After a half day, the moisture went away. But I guess the airseal or something isn't working anymroe. Well, if I bring it to the dealer, what should I expect from them to get this fixed?
This is 1st car in my life getting into this moisture issue. Lucky.
Thanks for your replies.
Got this checked during my 10k service. The dealer inspected it and found it's not the problem unless the moisture or water cannot be evacuated in a day or two. There are small holes insides which will help eliminate the water/moisture...
Dunno...
Dunno...
thanks for the info. had this problem with a different car and i had to bake the taillights. crack them open remove all the moisture and reseal them with silicon. didn't know that the holes would help. its also propably the problem.
The fogginess to disappear in a day or two? That is inacceptable. The light housing should not have any moisture period. Take it to the dealer and tell them to fix it. Maybe its not sealing properly and the rubber seal needs to be replaced. A foggy tailight is a safety hazard. And it will corrode whatever is inside quicker.
The problem is that this "only" happened 3 times with the size of approximately 5-16 square inch. (I got my RX since last May) In my cases, they are all disappeared next morning. Once in Vermont, in rainy day with temperature around 30-45 F, overnight; twice in Boston, rainy day, the similar temperature, overnight. In where I'm now, NYC, we have tried numerous times to pour water on the top of it for at least 10-15 mins, similar temperature, nothing happened. It's hard for me and the dealer to replicate this and present.
Unfortunately, not too many dealers are willing to replace this type of case if they cannot duplicate or they don't see the moisture insides.
I like to get the new one for usre. I don't like that "hole" idea, either. I agreed this is not right and they should do something about it.
Rxet, seems like you are having all kinds of fitment issue(s) with your 10RX. I had the exact same issue 2-3 times during Aug-Sep during unusually rainy months in DC area but will clear up overnight in the garage and did not have any issues since. “hole” in the tail-lamp and light housing is by design so I would not worry about the “holes” unless its plugged. Late model SC [i use to have one] were/are more prone to moisture build up in tail-light housing because it had extra outer shell that would separate over the years. My 96 SC only had minor issues but some owner had to use the “oven” trick to separate and reseal the outer shell. When you get a chance, take out the tail-lamp housing to make sure the “hole” [drain plug] is clear of dirt buildup or twisted closed [i guess anything is possible].
The car is new. If it hasn't been damaged/wrecked than it's under a strong warranty from Lexus, not the dealer. Plain and simple, tell him if he thinks it's normal then ask him to put you on a conference call with him and Lexus Corp to discuss it. You'll get a new tail light. He'll never make the call.
I dont want to belabor the point. But here is a worst case scenario. Here in Houston it rains a lot. If the inside of the tailight assembly gets foggy it means moisture. Over time this will hasten corrosion of electrical connections. One day you will lose your tail lights on a rainy day. A car hits you from behind because he doesn't see you. Accident. Injury. And worse.
nowstime
03-17-10 05:01 PM
