RX350 Transmission Oil Change (merged threads)
Old 06-19-20 | 06:52 AM
  #481
ColAngus's Avatar
ColAngus
Originally Posted by Clutchless
The average drain and fill amount is 1 quart 16 ounces to about 2 quarts or a little over. I think those that drain at the lesser amount actually have their transmission under-filled. I think about 2 quarts is closer to the proper level if you are doing a cold drain and fill. I did a few on a 2013 Sienna which as the same 6 speed transmission. It drained 1.5 quarts. I experimented with filling it with more fluid on each drain and fill. It shifted far better and had better initial throttle tip-in response from a stop when I added 2 quarts. I later checked the fluid using the temperature method and it was correct with very little overflow.
You are what makes forums still great! Absolute goldmine of info from you in this thread.
Old 06-27-20 | 09:57 AM
  #482
SkyKing901's Avatar
SkyKing901
Ignore this post.
Old 06-27-20 | 11:22 AM
  #483
SkyKing901's Avatar
SkyKing901
Just drained and refilled my atf. Came out exactly 2 qt. So I decided to try let the car runs until it reaches 104f. It took almost 6-7 minutes. Is that normal? about .25qt came out. Is that also normal? Any feedback would be great.
Old 06-27-20 | 12:40 PM
  #484
Clutchless's Avatar
Clutchless
That sounds correct for your car. The total fill amount does appear to vary among those who post. It may be how level the car is, or manufacturing tolerances, such as the original fill amount, or how each person measures the amount drained and replaced.
It does take time to warm up the transmission when just idling and not driving around.
If you had overflow at 104 and are comfortable with your work, then assume all is good and take it for a test drive.
Old 06-27-20 | 12:45 PM
  #485
SkyKing901's Avatar
SkyKing901
im asking since we got the same car. Driving is fine. Thanks.
Old 06-30-20 | 03:02 AM
  #486
crldz's Avatar
crldz
It's not clear - does the RX 3 gen has a transmission filter? I can't see it on diagrams.
https://www.japan-parts.eu/lexus/eu/...pan-atm#35168A
Old 06-30-20 | 04:52 AM
  #487
Clutchless's Avatar
Clutchless
The drawing you linked is for the transmission case. The filter is not shown in that drawing. It is shown in the drawing for the valve body and oil strainer which is another name for the filter.
It is called either the filter or the strainer assembly for the valve body by Lexus. You need to enter your VIN to be sure you get the correct filter. This is the correct page from the link you provided https://www.japan-parts.eu/lexus/eu/...l-strainer-atm
The fillter is inside the pan. This link is for changing it on an ES350 but it is almost exactly the same for the RX. https://www.clublexus.com/forums/es-...placement.html
crldz (06-30-20)
Old 07-05-20 | 10:27 PM
  #488
SL10's Avatar
SL10
just had my fluids drained and refilled, but the mec just did a measure of fluid out (1,9L) and added 2 bottles (2L). ES350 2013 has a total of 6.5 L i believe.
how precise should the fluid in and out be? would 0.1 L difference be a cause for concern?
Old 07-05-20 | 10:28 PM
  #489
SkyKing901's Avatar
SkyKing901
i don’t think so.
Old 07-06-20 | 12:57 AM
  #490
heshamos's Avatar
heshamos
Don't worry about it but try to stick to the exact amount you drain next time. Best way in my opinion is to check the level of oil at the operating temperature.
Old 07-22-20 | 09:09 AM
  #491
rababich's Avatar
rababich
I don't think .1L is going to make a difference. The previous owner of our RX did his own drain/fill and when I did one 10K later I got 3.7 qt out of the trans. From what I've been reading most people get 1.6 to 2 qt out. I put 3qt back in and will soon do another drain/fill to see what I get out. Trans has been running great, no issues.
Old 07-22-20 | 09:33 AM
  #492
Non's Avatar
Non
Maybe in your case it would be worth it to go through the fluid level check procedure? I would do it if an unexpected amount of fluid came out of my transmission.
Old 07-28-20 | 12:00 AM
  #493
Dxpliciton's Avatar
Dxpliciton
Has anyone located the fill and drain plugs on the F Sport? I will get down there and find it myself if i have to but would love the assistance ahead of time if someone has the answer. Thank you in advance for the assistance.
Originally Posted by snag
Ok, tried to do the transmission oil change as planned but not sure about where the oil pan and drain plug are located. Underneath of my 2015 f sport doesn't look like any of the videos on youtube of other RXs and highlanders! After removing the black protective plastic shield, it seems the black pan with drain plug that all videos show at the bottom, is situated vertically in my car?? At the bottom, next to the frame where the pan/drain plug should be, there is shiny transmission body and some funny looking bolts. Does anyone have a 2015 f sport that looks like mine and has changed transmission oil? Can you please post some pics and hints?
Old 07-28-20 | 12:18 PM
  #494
Clutchless's Avatar
Clutchless
Read post 487 and follow the directions in the video on the link.
Old 07-28-20 | 01:32 PM
  #495
NickSP's Avatar
NickSP
I just picked up 5 quarts of ATF ws from Lexus for my 2010 RX 450h. From what I've read if you only drain out 2 quarts max then why would the parts person recommend me that much?
