RX350 Transmission Oil Change (merged threads)
#858
I agree with RX in NC. I have performed many drain and fills on this transmission or variations of it on 5 vehicles over the last 14 years and I would not trust any torque wrench on the plastic overflow tube. You are more likely to break it.
Just screw it in with an Allen wrench unti it stops.
I have never found one to have become loose on a subsequent fluid change. 1.7 Newton Meters or 15 inch pounds or 1.5 foot pounds is so small I cannot believe there are many wrenches accurate enought at that little pressure. That really is just finger tight.
#859
Clutchless (08-12-24)
genji
CT 200h Model (2011-2017)
10-02-23 12:43 PM
2008, 330, 350, change, changing, drain, fluid, lexu, lexus, oil, part, plug, rx, rx330, transmission, transmission fluid, transmission fluid change, transmission flush?
