RX350 Transmission Oil Change (merged threads)
#91
Wow, that's funny!
Yep, that's where I'll be taking my (dads) RX and ES. I've had them flush (aka "complete fluid exchange") on my 05 4Runner and couldn't be happier.
So yeah, Lexus of Lehigh Valley won't service the transmissions which is complete nonsense. BUT, if they don't have the machine, what am I supposed to do? Bad on them (Lexus of LV).
#92
Wow, that's funny!
#93
Thompson is a hike for me. I live practically next to Lexus of Chester Springs but I don't care for them. Lexus of LV is ok, you have to get connected to the right person in service, but yes, they used to be better.
#94
well, if your serious about lolv. i recommend diana miexsell. my sales person at lolv was great. service, its ok. my next lexus will be from thompson. the only reason i didnt get it from them this time. was because the sales woman would not drive it up to me. but that has since been resolved.
#95
I go to LV b/c it's 15 drive from work and I can usually get a loaner (this is how I drove the NX, various ES's and IS's). Fond memories of Thompson, it's where we went to test drive the LS400 back in 1990. I could still see/hear/smell that car. Anyway, I still feel terrible when my mom traded in her 91 LS several years ago.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#96
Just got back from having the ATF "complete fluid exchange". Vehicle seems to shift "crispier" if that makes any sense.
Got it done at Bennett Toyota in Allentown, PA As I mentioned before, Lexus of Lehigh Valley wouldn't do it b/c "Lexus does no recommend servicing the transmission as it is a sealed unit". Someone over there needs to be slapped around. Seriously considering calling USA Lexus about this. Why some dealers offer to do this and other don't???
#97
#98
If you ever go to that Lexus dealer again you could point out how much money they could make selling transmission fluid exchanges that is now going to the Toyota dealer. I bet the ATF exchange machine would pay for itself many times over the first year. They cannot be that expensive if almost every Jiffy Lube and Midas has one.
Of course with Lexus and Toyota a large part of the cost is the overly (and unneccesarily) complicated fluid measurement system designed by their evil engineers/accountants to make sure only the dealer could do this, thus insuring a steady income stream to them.
Lexus/Toyota say they really do not want you to service it because it is a marketing thing, thus lowering advertised maintenance costs. Most if not all will last beyond any warranty without any such maintenance on the transmission, although shift quality may deteriorate some, most will not notice.
#99
So yes, I just got back from doing some office errands and the car does shift better (sharper, but not harsh). They have a 08 ES350 with 44K on the clock, I'm thinking of getting that ATF changed this summer, but am having seconds thoughts as we don't use that car very often.
#100
any particular reason you guys want a complete flush vs a drain and fill? im at 20k thinking about doing a drain and fill at 30k. in the past ive just drained and filled all of my vehicles ATF without any issue.
Also is there a part number out there for this fluid?
#101
I did a drain and fill on my RX and because of the quirks draining this transmission, go to page 4 of this thread as it provides instructions, you should read them the first time. Look at the Mini Cooper PDF I posted as it has almost the same transmission and the same drain and fill procedure. Except the RX is much easier to get to the fill hole. It takes Toyota WS (for World Standard) Automatic Transmission Fluid. However, it is over priced and not synthetic. I instead used Mag One Low Viscosity Full Synthetic ATF. Available at Amazon. http://www.mag1.com/productdetails.a...a-55f0b5c590fe It has had great reviews at www.bobistheoilguy.com where I learned about it.
I also read that Pennzoil Platinum LV Multi-Vehicle ATF works well as a WS substitute and is synthetic. The LV stands for low viscosity which is what you need as WS is low viscosity. http://www.pennzoil.com/en_us/produc...5uem9pbC8wMQ==
I initially did 2 drain at fills at about 34,000 miles then another one a few months later when I changed the oil. I think it shifts better now. I plan to do a drain and fill at every oil change, which is about once a year for the low miles I put on it.
#102
greeknasty^^^^ because a drain and fill on these box`s only gets out about 2 qts. and i have no idea why? my other two rx`s (2001 & 2005) i got out 4+ qts on drain and fills.
#104
i c. well this is why i am going to do a complete flush @ 30k.
#105
So? Toyota/Lexus trannies call for WS and from the millions of thread I've encountered over the years, there isn't a definitive substitute for WS ATF. I would play it safe and still with the Toyota/Lexus WS ATF.
or by disconnecting the cooling lines (in and out). Doing it this is pretty much ensure ALL the old fluid is out, this is done by observing the "outgoing flow" and if it's bright red. If so, you are done.
