Power liftgate button question (merged threads)
#31
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
I know this is a old tread but
Get a bluetooth obd2 plug for under the dash and get a app from playstore called Carista.
It allows you to change a lot of options not allowed from the nav screen. Including disabling seat belt. Cost 20 but worth it imo.
#32
#33
Yup ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Carista can activate "Rear hatch opening assistance", which means having it open by itself when you press the button.
Please let us know if you have any questions or run into issues. See my signature for more info on the app and hardware adapter. Available for iOS and Android.
#35
We don't have the options to add/ program smart keys or register ECUs, but we are working on the TPMS. So far we can read the IDs of the sensors and we are working on adding the option to save new ones.
#36
#37
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/421x600/button_175a2b59d260a1b60c85c13e135550d38e5b2310.jpg)
I don't know what year your RX350 is, but I have a 2013 and thought I had the same problem when I first got it. The dealer showed me a button behind the glove box cover on the left hand side that controls whether you can operate your rear lift gate with your remote control. Open your glove box and look on the flange for the button (see picture).
#38
My rear lift gate on my July, 2010 built RX350 was not opening with assistance, just manually.
I hooked it up to Techstream and found the setting to change. It is contained under the menu setting for "PSD and PBD Operation".
Works like a dream.
Works like a dream.
#40
Techstream also allowed me to program a Smart Key Card and turn off seatbelt chimes and change other settings.
#41
#42
Hi, this is my first time using this site! I just purchased a 2010 RX350 and am experiencing the same issue...tailgate will not open itself via the release above the license plate, just unlocks the tailgate. I bought the Carista adapter and downloaded the app but I do not see the feature in the app. I've seen screenshots others have posted, but for some reason it is not showing in mine. And yes I do have the power liftgate haha. Any help?
#43
Please tell me there is a way to open the rear liftgate by pushing the button in the rear? I know you can open it by power from inside and remote but for some reason not the rear button?? It makes no sense to me. My wife never takes the remote out of her purse so it seems silly to have to dig in your purse to find the remote.
There are two buttons covered in black rubber. The small more pointed spot under the rubber cover is the LOCK button. The wider button to the left of the LOCK button is the power door open button. If that button is not working it might be two things. It will only work without the FOB nearby if the doors are already unlocked. You can press the button to open the tailgate without the FOB nearby if the door are unlocked. If the doors are locked you must be carrying the FOB with you, but you shouldn't have to take it out of your pocket or purse. You will also have to hold the button for about 2 seconds to start the door opening. You will hear the warning beep when it opens or closes. When the tailgate opens the rest of the doors will remain locked. The rear tailgate open button is active by default from the factory, but can be disabled by the dealership. They should not have disabled it without telling you, but if you purchased the car used it may have been re-programmed to disable that feature. It is easy for the dealership to set the tailgate open mode with their SCAN tool. Us mortals can't do it. Lexus chose to not make that function one of the user configurable items in the various menus. Why, I don't know. It's not that special! Once you get the tailgate button working remember you don't have to wait for it to get all the way open to stop it. If you press the button again after it is opening it will stop, right where it is.
#44
On our 2013 RX450H rear hatch.......just press the button by the license plate and hold it for like a second or two and then there is a beep and let go. The rear hatch will power open by itself. I wished this were true in our 2013 LX570! !!!
#45
I just realized this was an old post!!!
