AWD Snow Prowess
Could someone clarify for me----I thought the lock button was something to be used only when starting out/stuck in the snow and that it shuts off automatically at about 30 or 40 mph ?? Should I be hitting the lock button myself when cruising along the highway at 40-50mph on snowy roads (like last Thursday in MA)? or does it engage by itself when it feels it is necessary?
I bought the car in July, so I didn't think to ask the dealer snow-related questions.
I live in NE as well, we had a RAV4 with the same electronic AWD system as the RX. It is surprising good for a reaction based AWD system, especially when combined with Lexus' stability system. Lexus's electronic AWD system is light years ahead of the on in my old MDX, which uses the same type of AWD system. We traded in our RAV4 a few months ago for a SUV with permenent AWD. The permenent AWD feel more secure on snowy highway and it doesnt need to detect slip before it goes into AWD mode. Sometimes that split second that it takes to send power to the rear wheel means a lot.
My 450h has 'hybrid snow' mode that fires up the rear wheel motors at speeds under 35MPH continuously instead of waiting to detect a slip. When engaged, the RX compares well to the X5 BMW AWD.
On ice I miss my Goodyear triple treads -- amazing control in awful conditions. The RX does well but not as well as the so tired X5.
I was thinking of getting the 450h-like SUV in the future in addition to the permanent AWD vehicles if 450h electric motors can work all the time.
> I thought 450h can act like the full-time AWD, do you mean that the speed restriction - 35MPH
I don't know if its 35mph, but I do know there is a 167hp supplemental electric motor in the front and a 67hp electric motor in the rear without transmission, so it must disconnect at some point, and can't provide full torque. For the 350, the diff lock goes off at 25mph.
Pretty interesting. I thought 450h can act like the full-time AWD, do you mean that the speed restriction - 35MPH is still applied on 450h? Thanks.
In Hybrid Snow mode they are powered continuously below 35 MPH and cut out above that, and back in regardless of traction status as you slow down below 35 MPH.
I haven't found any documentation regarding the system specs, so these are just my observations.
While in Hybrid Snow mode, the middle 'eco' light never comes on, and the battery drains more quickly. The regenerative systems seems to operate as usual.
This tells me that the rear motors are quite a drain on the battery and that's why the system uses them very sparingly in most driving conditions. Hybrid Snow is to be used when things are really tough.
I haven't run Hybrid Snow continuously long enough to know if it would drain the battery below tolerance levels, but I have to say it looks as if the potential is there.
The way to test it would be to take a prolonged trip below 35 MPH in Hybrid Snow mode.
Betcha the rear motors kick out before the battery gets in trouble.
All that said, my experience so far is that the system transitions from FWD to AWD seamlessly and automatically in winter driving conditions. I can't say that the full time AWD vehicles I have owned had any real advantages. They did burn 30% more fuel all of the time. So there's that.
My advice would be to take a 450h out on a test drive in awful weather and see what you think.
p.s. anything in cars and such things for most users are userfriendly, that means if u can touch it or press it so ú won't brake it...even you put in P on 100km/h nothing will happen...
I was driving on a back road and playing with the settings. If you follow the energy consumption graphic that shows what the system is doing, the rear motors are not powered unless slip is detected, then they cut out as traction recovers.
Well, really appreciated your notes above. This is the great observation! Wish someone here can find teh tech manual and post it here in the future.
How's your RX moving so far over there? It seems Europe is also full of snow.
As car to be driven safely on snow conditions, it is working very well, though as a AWD to have some fun with is not good at all...AWD system is constanly overheating (showing on display) and it is not making powerslides anygood...
Compared for example with Toyota LC200 > LC is just pure fun going sideways on such road conditions...
Comared with LS600hl > it is ***********g scary to get it sideways, because it looses end soooo widely, that before starting to powerslide, it looses car end through 2-3 lanes and just then it starts to tow out, though LS600hL has very good AWD system that has TorsenLSD in it...
P.S. if u're watching the news with London UK and see panic there, or Paris France...it is not a problem in my country or countries around because in winter time it is a MUST to have winter tyres on...in FRANCE, UK and othe West Europe countries it isn't so, so they have such problems if snow occurs...
yeah, got some snow, but not as much as in canada (saw some photos recently, where there is like 2meters of snow )
Even in Georgia
We usually get one or two notable snows a year that cover the roads. Last nights was no exception other than we're loaded with a bunch of idiots down here as the video link will attest. http://www.11alive.com/weather/story...139464&catid=4
I took my RX450h out early and made some of the 1st tire tracks. It was about 22 F and the snow was a crunch type that was powder if you tried to make a snow ball. The car performed so well I couldn't tell when I had the snow mode on or off except from the light in the dash. When stopping hard the brakes would alternate and pump as necessary to stop straight and not slide sideways. I consider this perfect in a car as heavy as this and as tall as this. When accelerating hard enough to break traction, it just seemed like it would retard the throttle if traction started to break. When taking a turn I found out that unless you just insisted on living too far in the fast lane, it held it's own in the turns. BTW, I have the 19" Michelin's.
Bottom line, you had to try and try hard to get out of control below 40mph. I didn't get to go faster than that. No complaints, just admiration.
Now for some laughs at the expense of GA drivers. It appears in the video that one 2nd gen RX driver pulled off the road to let krazy's by and one Lexus sedan was an early enough model to not keep the driver (lady) from doing a 180 and using the side of a pickup to stop. for her
