What is the easiest way to replace the fog lights?
I wanted to replace the stock fog lights with some PIAA 3000K blubs. Is there an easier way to do it without taking off the bottom plate? It is very cold outside, and didn't want to do all that work.
Any help guys.
I replaced mine with 4800k. They match the HID headlights much better than the stock bulbs. I came in through the bottom by removing the bottom skirt and the two lower pieces of each front wheel well. Not the easiest things to get to. I never thought of going from the top. Either way you have a lot of plastic to remove. Looks alot better. Be sure to stick to the 55 watt bulbs. I got a set from e-bay for $8 incl shipping. They actually work. Good Luck.
Any help guys.
just to confirm your question, you are looking to install a PIAA 3000K HID kit correct? because just fitting in 3000K bulbs into the fog lights won't work, you need the HID ballasts to go with the HID bulbs. either way, you need to take panels off to do this, so i would recommend you do the install properly.
55 watt bulbs? Isn't that a tad bit hot? I've used 35watt bulbs in my fogs where originally it was a 55watt system, and it's worked fine. I'd be worried of 55watts being too hot for the housing.
