Mud flap rx350
#61
Easy 20-25 minute install.
I used a Torx screwdriver but a 4mm Allen wrench works well along with a 10mm socket ratchet.Cut the front wheels for more room.
The rears a 10mm socket ratchet and a #2 Phillips Screwdriver stubby if I remember correctly..
#63
No, I don't play soccer!
Drilling was required on the 2nd gen, not 3rd gen best I can remember. My dealer put them on for me
Sweet price. Some people got them for four times that much
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#67
Yes (1/4"), the same diameter as the screw since the spring clips is what holds the screws intact for the rear mudguards.
http://lexus.sewellparts.com/pdf/PT76948100.pdf
#68
It's necessary for the '10 rx, you wont be able to put the rear ones w/o drilling don't worry if you know how to use a drill you'll be fine. A smaller size drill bit will do and then use the screw that comes with it.
#70
Oh yes sorry when I said drilling I meant you need a hole no matter what....
#71
A few of us bought Lexus mud guard kits from a Canadian dealer and drilling wasn't necessary with that kit.
Here's the thread.
https://www.clublexus.com/forums/rx-...ashguards.html
#72
yahj,did you get self tapping screws with the mud guard kit for the rears?
Here's the thread.
Here's the thread.
#74
