2010 Low Gas MPG
Ok, so I just finished my first tank of gas in my new 2010 RX AWD. The car came with a full tank of gas compliments of the dealership so I'm assuming they filled it up with the recommended octane. I can't believe the average MPG showing on my dash is 12.9. I did mostly local driving, but this seems extremely low for a brand new car that is supposed to average at least 18 for city driving.
Is this possible?
Is this possible?
I have the mileage computer set since the car was new, more than 4000 miles ago. I'm averaging 22.3 mpg, all kinds of driving. About half the miles were at speeds around 80 mph across the desert interstates.
Is this possible?
Is this possible?
You car may get the better MPG later. Try to properly record down all the MPG per tank. You probably will see the improvement in the next few hundred of miles.
Btw, where do you usually drive? If in Manhattan, that number seems quite normal with the big foot. Some ppl got even worse.
Remember - 18 MPG in City isn't applied to everyone. It's hard for most of ppl to replicate the similar environmental factors. Someone will get better than 18; others will get worse.
EPA says "The city and highway tests are currently performed under mild climate conditions (75 degrees F) and use acceleration rates and driving speeds that EPA believes are generally lower than those experienced by drivers in the real world. Neither test is run with the use of accessories, such as air conditioning."
Sorry if I'm a little ignorant for taking the first tank of gas estimate seriously. This is my first luxury vehicle and I thought the mpg calculations were almost accurate, give or take a little. Not sure why the mileage would change the more I drive? I thought being it's a new car it would be the best mpg right now.
Most of my driving is on Long Island . . . local suburban streets during the week mixed with highways on the weekends.
I have no idea how the car calculates the mpg, but it's never been even remotely close to my own tank-by-tank numbers over the 8 months I've had the car. I pay no attention to it. I'd say I average 19-20 but less in the winter months--16-17.
Is this possible?
Is this possible?
With a new car being picked up, the dealer spends some time going over the features. Chances are, to keep the battery from running down, the vehicle was running during the demonstration. During that time, you were getting 0 mpg which will be averaged in to whatever values you get while actually driving so the average will be artificially low. The same occurs if you make changes, listen to the radio, etc. while idling wihtout moving. Make sure you reset the average values when you fill up and start tracking from there being concious of non-essential idle time.
Good point Ziggy. Don't judge your MPG off the first tank. Give it at least 10 tanks and take the average.
I would not assume that the Lexus dealer filled it with premium. Any new car will not get near the best milage until it is broken in. Give it some time and relax and enjoy!
