leaving keyfob in unlocked 2010 RX350
Old 03-17-10, 10:52 AM
rftuck
rftuck's Avatar
Smile leaving keyfob in unlocked 2010 RX350
I notice that if we leave the keyfob in the unlocked SUV that it blinks the little red light on the keyfob. Is this running down the keyfob battery and should we not leave the keyfob in the SUV?
Old 03-17-10, 01:57 PM
LeoDLion
LeoDLion's Avatar
When I accidentally left my key fob inside the Rx and close the door, it made a loud quick beeping sound. I was impressed.
Old 03-17-10, 02:34 PM
rftuck
rftuck's Avatar
Was the keyfob red led light blinking while in your RX?
Old 03-17-10, 02:48 PM
integlikew
integlikew's Avatar
I don't know If it blinks since its in my pocket all the time, but common sense tells me if a light is on or blinking it is useng the battery and will wear the battery down sometime.
Also I don't think many people leave the key in the car, since it wont lock. If they do its only for a quick sec. so I wouldn't worry to much.
Old 03-17-10, 04:24 PM
rftuck
rftuck's Avatar
I am trying to get my wife not to leave the keyfob in the Rx. Hopefully she will abide.
Old 03-17-10, 05:37 PM
integlikew
integlikew's Avatar
Should have told us that in the beginning. I would have told you to give up.
Ohh and where do you park this RX with the key in it might I add? LOL
Old 03-18-10, 05:34 AM
LeoDLion
LeoDLion's Avatar
I just tested it. No the key fob is not blinking. As soon as I try to lock the car, a blinking message shows up "Key inside the cabin". Then a high pitch sound. When I recover the key inside the cabin and lock, the sound and message went away.
Old 03-18-10, 07:33 AM
rftuck
rftuck's Avatar
Where does the blinking message show up, on the nav screen or ?
Old 03-18-10, 07:43 AM
jimmyford1
jimmyford1's Avatar
As you found out, the car will not lock with a key inside by touching the door handle. If you have a need to lock the car with a key inside, you can do it by pushing the lock button on the second remote. You will also have to unlock using the remote.
Old 03-18-10, 10:04 AM
integlikew
integlikew's Avatar
Good to know I didn't think it would lock even with the 2nd remote.
Old 03-18-10, 10:10 AM
integlikew
integlikew's Avatar
In the middle of gauges on the dash.
Same thing if you try to start the car with out the key, or get out of the car with the key in your pocket while its running. It will say "KEY NOT DETECTED" in that same place.
Old 03-18-10, 12:31 PM
jskennedy
jskennedy's Avatar
where is the light on your key fob
i must have the unlit version
Old 03-18-10, 12:38 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,311 Likes on 1,410 Posts
Don't leave the keyfob in the car. Your vehicle and the FOB will "talk" to each other all the time when they're in a close distance and you will run down the battery.
Have seen other threads about this with members who experienced it - can't find them this second.
Old 03-18-10, 01:00 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
That makes sense since changing the battery is now part of the service. Thanks!
Old 03-18-10, 01:53 PM
wyau01
wyau01's Avatar
Didn't try that, but you could lock the car using the metal key.
Quick Reply: leaving keyfob in unlocked 2010 RX350
