Old topic but fits my problem. Warranties have long gone and I have had several noise free years with Rxs.
But I replaced rear shocks last week. Result much better ride and squeeking noise back there.
Shocks are Kyb gas shocks, decent quality I guess. I could say noise has come only from right side.
In this case I could rule out the interior parts but with the topic I do not do any sudden action for the noise.
About 3 weeks has passed and I haven't heard a thing back there since I wrote above.
Originally Posted by roy7777
I found a trailing arm bushing on Amazon, "Febest TAB-368", which costs $80. Who wants to try it?
Originally Posted by Clutchless
The problem is installing the bushing into the arm. You have to remove the old one which is glued/welded/molded into the arm. Then somehow attach the new one to the arm. This is very difficult and needs specialized equipment most of the time. That is why most places just replace the arm. It is much cheaper.
I agree. When I had high mileage Rx400h, I had to replace some suspension components. The aftermarket parts were so well priced I did not even consider replacing only bushings with the exception of the rear wheel carrier lower bushing. I installed Febest bushing in the carrier which wore out in months and had to put original part there. That worked until I traded the vehicle.
I changed out both rear trailing arms. The bushings were the issue but they don't simply swap out the bushings as it doesn't come as a separate part. It was a $1600 repair. (fixed under warranty after threatening, yelling and haggling)
It's been 18 months and the squeaking noise is back in the driver's side rear.
Just reporting that it's really loud now. VERY LOUD. Anytime there is a speed bump or some kind of parking lot bump or dip it makes the noise. Sounds very cheap. My 250K miles old Gen 1 RX doesn't do this............
New to forum here, came here for different problem but found this thread. I too have this squeaking sound from the rear when going over a speed bump, hump or dip on my 2014 RX350. Started to notice the sound at around 40k miles. I always thought that it was the rear shocks, after I replaced the rear shocks at 65K miles, the squeaking is still there but a lot quieter. New shocks limit the the car from bouncing up and down hence the squeaking is less loud. At this stage we're just gonna live with it.
Can you please share? Which aftermarket parts are you referring to. Any hyperlink you can provide?
I am sure he meant the rear trailing arms. It is the circled part in post 89.
I read that. But that post deals with just the bushing. I thought we had to replace the whole trailing arm. On my Gen 1 RX, I've tried aftermarket bushings before. They were all bad. Too stiff and too easy to crack and break.
That was what was indicated, you need to replace the entire rear trailing arm as it is almost impossible to replace just the bushing and that there are aftermarket rear trailing arms available for a reasonable price. Any local repair shop could install them for you or if handy, do it yourself.
I see that aftermarket supplier Mevotech makes them as the 2014-2018 Toyota HIghlander now has the same rear suspension as the 2010-2015 RX. Saw them on eBay for about $82 each. Also at PartsGeek https://www.partsgeek.com/gbproducts...ad=47433948492
Has anyone tried this Mevotech part? Any reviews or thoughts?
Also can I just do one side or should I do both sides like a strut? Finally, do I need to do a wheel alignment after replacing?
I replaced my OEM one with the Mevotech a few months ago. There's a thread about it here: link
Seems to be working fine for me, and I picked up one for the other side I plan to install before winter gets here. I didn't do an alignment, at least not yet. No good reason for not doing it, just haven't yet.
See the attached instruction on how to mount the rear struts.
I had a hard time taking the bolt out, because it was so thick with rust it became one with the bushing, so the bolt only came out after soaking it with penetrating oil.
While turning the bolt, the whole rubber bushing ripped, this was the cause of the squeaking.
In the instruction, you can see that they've changed the bolt torque and type of bolt.
